Regular Street Shoes
Tom Windsor
08-22-2006 21:14:21
third party image
Sandblasted, assembled, primed, mounted and getting fitted with street shoes. Next, final paint, rubber and then drag racing!!!!
Jim Lockhart
08-23-2006 11:31:51
 Re: Regular Street Shoes in reply to Tom Windsor, 08-22-2006 21:14:21
On the 2 sets we made,we used 1/2" thick.Then we put 4 3"by3" tabs with a hole,welded them to the ring where they could be bolted to the cleat.The bolt ran under the point of the cleat with a 3"by3" washer on the opposite side of the welded tab.
As far as the rubber goes,we used old belting from a round baler,cut to width,the we used contact cement on the rim and rubber.Also put in a few well placed stove bolts(small ones) to help hold the rubber.st what we did,hope it helps.I may have a pic or to if ya email me.
Tom Windsor
08-23-2006 13:23:38
 Re: Regular Street Shoes in reply to Jim Lockhart, 08-23-2006 11:31:51
I would have preferred the 1/2 inch rim but I did not have the capability of bending metal that thick. With the 1/2 inch it would be good for the tabs and bolts that you mention. I am not certain about the thinner metal. It may be that I will have to put spacers and bolts between the ring and rim at mid way between the spikes due the thickness of the metal.
Dont know yet.
moseed
08-23-2006 06:15:55
Tom,
What thickness and width are you useing for the road rings your building? Your picture has me motivated. Any trouble to be looking for?
Thanks
Tom Windsor
08-23-2006 09:39:27
 Re: Rubber and some details in reply to moseed, 08-23-2006 06:15:55
Yes, I intend to attach rubber to the rings.
The rings are 4.5 inches wide and 1/4 thick. They turned out 4.5 inches because that was the width of the scrap on the floor at the fabricator.
I took the cleats down to my friends sheet metal fabricating business and told him to make me some rims to fit them. 1/4 inch was the thickest he could roll on the machine that makes this metal curve. He made two halves which I intend to fit snug, cut to length and weld together to make ring. The c clamps were to get it snug before cutting to length. I have not decided on how to attach the ring to the wheel yet...still thinking about that.
Ron in Nebr
08-22-2006 22:37:24
I'd think those C-clamps would make for a kinda bumpy ride on a hard surface.....altho they might give decent traction in loose dirt....:)
Seriously though, it's looking good! I take it you're planning on covering the rings with rubber somehow?
Mike CA
08-22-2006 21:16:50
I bet those will be a smooth ride on your local roads. Fast too! :-)
