Question about Iron Guard paint
R Wyler
10-03-2005 17:31:08
I am going to be painting my IH 510 drill soon and I think I will use iron Guard their canned "non Aresol" acrylic enamels seem to hold up well or at least their Case desert sunset does compared to the spray cans. First off does Valspar mfg their Iron Guard?? also would it be wise to use a hardner in this? I was thinking Case had hardner as well and if not would the BPS Valspar hardner that TSC sells work with it? I also wonder if the BPS primer would work with Iron Guard. Sorry for all the questions but I am haveing a lil trouble figureing out just how to go about this. I appriciate any info. R Wyler
Paul in Mich
10-03-2005 19:58:27
 Re: Question about Iron Guard paint in reply to R Wyler , 10-03-2005 17:31:08
Whether you decide to use hardner or not is a matter of choice. I, myself, do use hardner, mainly because it sets up faster which allows me to apply the next coat faster, and as it sets up faster is not as apt to get bugs or dirt in the wet paint. As for other products, I have always prefered to use IH thinner and IH primer if using IH paint. Doing so ensures that you are using products that are compatable to eachother. I sort of became entrenched in that mindset after having to repaint a hood, grill, fenders and a lot of the periferal tin work because I used a thinner which was supposed to be compatable, but wasnt, and I ended up with a lot of fish eyes. I"m not saying that there arent other products which are compatable with the IH paint, but after that experience, which entailed a whole lot of sanding, I decided that I can"t go wrong using all IH products. I"d do the same if I was using DuPont or Martin Senior or any other brand of paint. Good luck. It may be a bit scary at first, but once you realize some positive results, you"ll trust, and appreciate yourself as a painter as much as someone else.
R Wyler
10-03-2005 20:11:34
 Re: Question about Iron Guard paint in reply to Paul in Mich, 10-03-2005 19:58:27
Thanks that does sound like good advice I will get the IH primer and reducer as well. I have heard about needing to use compatible products and I sure dont want the paint to fail any time soon. I have used a spray gun enough to be fairly comfortable with one for painting farm equipment so I shouldnt have much trouble. There will be some sanding involved as I want it to look nice for the decals. I need to post pics on here of its progress.
RustyFarmall
10-03-2005 17:54:32
The paint that is in the aerosol cans is the same paint that is in the quart and gallon cans. I have used a considerable amount of both and it holds up very well, no matter what kind of can it came out of. My personal opinion is that hardener is a waste of time and money. If you do use the hardener be advised that a full air supplied respirator is required.
R Wyler
10-03-2005 17:59:32
 Re: Question about Iron Guard paint in reply to RustyFarmall, 10-03-2005 17:54:32
Ok that is good to know as I still have box of 6 cans of that 2150 and I painted one of the press wheels a couple years ago and it has sat out the entire time and it hasn't faded at all. I know what you mean I am leary of the hardner as well I just want it to be good. Course that Iron guard is alot tougher than that junk they sell at the farm stores :>) I was going to get my white at tsc I will see of they have it at the dealer. Thanks for the input. R Wyler
RustyFarmall
10-03-2005 18:11:00
 Re: Question about Iron Guard paint in reply to R Wyler, 10-03-2005 17:59:32
I have purchased the white at my dealer, so yours should have it. One thing to keep in mind when you hear people talking about the hardener, IH did not use any hardener in the paint when their machinery was painted the very first time, and it still looked very good for many, many years, even on the equipment that sat outdoors all the time.
CNKS
10-03-2005 19:50:31
 Re: Question about Iron Guard paint in reply to RustyFarmall, 10-03-2005 18:11:00
There seems to be a misconception about hardener. While it makes paint flow out better and adds gloss, it does not inhibit fading. Fading is reduced by the UV inhibitors included in the acrylic modified 2150 or other paints themselves. A tractor that has had hardener applied "may" appear to fade less, that would only be because it was glossier to begin with.
Peabody
10-03-2005 20:44:41
 Re: Question about Iron Guard paint in reply to CNKS, 10-03-2005 19:50:31
OK, CNKS, then please give the straight talk on hardener. All the research I've done really scares the poop out of me concerning the adverse health aspects of using hardener without a supplied air breathing system. What overwhelming benefit does hardener contribute that would either justify purchasing a supplied air system or taking your chances with a less-protective cartridge air filter mask. Bottom line, as I've said several times before, I sprayed IH 2150 over two years ago WITHOUT hardener and the tractor still looks great (kept under cover). I get alarmed that first time painters are lured into some kind of mystique that hardener is a superior additive, without knowing that it has possible detrimental health consequences. From your comments, shouldn't we leave suggesting hardener to professional painters (if at all), or am I just a wimp? Personally, every time I see a post about possibly using hardener, I'd like to say, "Forget it."
CNKS
10-04-2005 12:10:41
 Re: Question about Iron Guard paint in reply to Peabody, 10-03-2005 20:44:41
Peabody --- I always give straight talk about hardener. I always say you MUST use a supplied air system with it. I was a 1st time painter about 4 years ago (unless you include the mess I made of a pickup in the early 80's). I read up on it before I ever started, and had my ducks lined up. If you use hardener USE A SUPPLIED AIR SYSTEM. Then you don't have to be afraid of it. --- I am "sensitized" to the isocyanates in hardener, likely because I spent years spraying herbicides in my previous job without wearing a mask. I cannot do even one squirt of iso containing paint without feeling the effects. I know beyond a shadow of a doubt what iso's can do. With a supplied air system, I will not get the effects, I do have to be cautious about reentering my painting area --- I use acrylic urethane, it has to have hardener, it won't cure without it. Synthetic enamels, acrylic modified synthetic enamel (IH 2150 and others) and acrylic enamel can be used either way. Hardener makes the paint cure faster. At least with acrylic urethane, any mistakes can be sanded out and either compounded and polished, or recoated the next day, depending on what you want to do. As to being scared of the stuff, the Paint and Bodywork Forum on this site is one of the few sites where the participants insist that a supplied air system be used, even for a one time painter. You are safe with supplied air systems because they are positive pressure, ie the air comes in and keeps the fumes out. With a cartridge mask you are breathing the fumes in, if the mask does not fit or if the cartridges aren't new, you are getting fumes. You will pay more for the supplied air system than the paint will cost. That said -- I am not an expert painter. You and others may be able to get a better appearing finish with 2150 without hardener than I can get with PPG Omni Acrylic Urethane with hardener at $100 plus a gallon -- I haven't used the $2-300 stuff yet, but I am considering it. I like the way it flows out, I like the coverage, I like the easy to use primers and surfacers I use under it. I like to be able to add a second coat within 10-15 minutes of the previous one. I like the fact that it is almost impossible to get runs and sags with it, at least with a good HVLP gun. Painting is an integral part of the "restorations" I do. I don't do shortcuts. Every part is removed and taken to bare metal -- I am not bragging, I'm not saying my tractor looks better than yours, I'm simply stating the way I do things. I am retired, this is what I do in my retirement. I am not going to work several months on a tractor and put cheap paint on it, even if the stuff does "work" -- my tractors and I deserve better after all that work. Paint is only a fraction of the cost of the whole job anyway. I am sorry that RustyFarmall and others seem to take offense if I say there is better paint out there, and cannot understand that there are people willing to spend more money for products they consider better. I may have said the following statement earlier, I don't remember -- and if anyone wants to correct me please do so, along with explaining why. "Several people have used CIH 2150, moved up to acrylic urethane, and have never gone back to 2150. I have not heard of anyone who really wanted a good job that used acrylic urethane, then went back to 2150". But, anyone can do what they want, if they are happy with it, so am I.
Peabody
10-04-2005 13:11:58
 Re: Question about Iron Guard paint in reply to CNKS, 10-04-2005 12:10:41
Thanks for the reply, CNKS, I see where you are coming from. My main concern is the obvious first-time painters who ask the question, "should I use hardener?" and inevitably receive replies that they should use it, with no mention of the need for supplied air.
CNKS
10-04-2005 13:42:42
 Re: Question about Iron Guard paint in reply to Peabody, 10-04-2005 13:11:58
You won't get that answer from me--but, most people are not aware of the hazards -- the OWNER of the place I buy paint says a charcoal mask is ok with hardeners, because "that's the way we have always done it". Thus, I have little confidence in paint salespeople. People vary tremendously in their tolerance of hardeners/isocyanates -- sooner or later if you use only a mask they will get you. Slightly off the subject -- Rusty said to leave the $300 paint and hardeners up to the professionals. With a little practice, most people can do BETTER than the professionals, mainly because we can take more time.
RustyFarmall
10-03-2005 22:53:47
Peabody, I couldn't have said it better myself. Let's leave the hardener to the pros, along with their $300 a gallon automotive paint.
R Wyler
10-03-2005 20:06:04
This may sound like a dumb question but is all the 2150 they sell acrylic modified? the iron guard that I have used so far and without hardner does seem to hold up very well and works easily and is simple for a non professional painter like myself.
CNKS
10-04-2005 12:25:46
 Re: Question about Iron Guard paint in reply to R Wyler, 10-03-2005 20:06:04
CIH 2150 is an "acrylic modified" synthetic enamel. It used to be plain old synthetic enamel, not much better than the stuff you buy in Farm Stores. I do not know when the change occurred. Far as I know you cannot buy the older formualtion from CIH anymore. It does contain UV inhibitors that slow fading, compared to the older version. I am not a paint chemist, but reading between the lines, it is "probably" as good as acrylic enamel. It is designed for people who want a decent job, and who don't want to sacrifice a portion of their anatomy for acrylic urethane. Acrylic modified paints are usually considered a form of "fleet" or industrial paints, that as I said are decent and inexpensive. When it comes to paint, you can look around and find something for everyone.
R Wyler
10-04-2005 17:18:34
 Re: Question about Iron Guard paint in reply to CNKS, 10-04-2005 12:25:46
Thanks for the info it sounds like it should be decent. I will see how it works out soon. I know what little of it I used a almost 2 years ago hasnt faded any that I can see.
R Wyler
10-03-2005 19:04:50
Yes I am sure my closest dealer will have the white. After thinking about this I got to thinking about that bps and I think its oil based. I will get a gallon of the red and one of the white it dries alot faster and harder even without the hardner. I know its because it is acrylic. That is interesting about them not useing hardner that makes me feel better at least I know if I dont use it I am not cobbling it up ;>) After thinking this through that 2150 by itself should do great on there. I may get some primer also when I am there.
