How many Regulars had electric start?
FmrBoy
03-28-2005 09:40:27
Hi seen a regular with electric start and am curious if this was something someone put together from F 20 parts if they actually built some? Also the front end looks like it was switched to a F 20 front end because the steering box is closed in, doesn't have gears in the open. No holes in the hood, exhaust is down below like Regulars were. Thanks guys trying to figure it out.
SproutW
03-28-2005 21:30:52
 Re: How many Regulars had electric start? in reply to FmrBoy, 03-28-2005 09:40:27
Did any of the last regulars come from the factory with the enclosed steering gear?
ihkovas
03-29-2005 00:04:49
 Re: How many Regulars had electric start? in reply to SproutW, 03-28-2005 21:30:52
SproutW,The only Regulars that had enclosed steering boxes factory installed were the ones that had the wide-front end option. The parts book I have shows these had the duck-bill steering that was later installed on early F-20 and F-30's.
SproutW
03-29-2005 12:37:32
 Re: How many Regulars had electric start? in reply to ihkovas, 03-29-2005 00:04:49
Thanks, I thought I had heard sometime in the past that a few regulars had the enclosed steering gear.
F-Dean
03-28-2005 15:24:39
Many farmers replaced the "Thumb Breaker" steering gears on a Regular with the enclosed worm-gear steering mechanism like a F-20.
Mike Androvich
03-28-2005 11:40:09
There were no Regulars built with factory electric start. Any that you will see are aftermarket. I have one that has a Montgomery Wards unit on it. I suppose that one could put on the aftermarket F-20 electric starter. There were no factory electric start F-20s either. Hope this answers your question!
