Farmall model M
Day Brown
10-27-2004 00:35:56
Says the serial number should be on the left side of the clutch or tranny. cant find it. Engine has:
6722-DJ and nearer the front: .4.21.T.
the logo on the hood was double printed. odd.
sammy the RED
10-27-2004 06:56:31
 Re: Farmall model M in reply to Day Brown, 10-27-2004 00:35:56
The other logo is from a earlier paint job.
Randy in NE
10-27-2004 04:18:27
The 4.21.T indicates that the engine block was cast on April 21, 1950. A J=1940, K=1941, etc. They used both U and V for 1951, Z=1954 and then they started the alphabet over again in 1955 with an A. The serial number tag probably got knocked off/removed over the years. I'm not sure about the M's but my C has the serial number embossed on a flat machined spot right below #1 spark plug.
rustyfarmall
10-27-2004 04:46:29
 Re: Farmall model M in reply to Randy in NE, 10-27-2004 04:18:27
The M will also have the engine serial # in a similar place.
