WHAT DO I REALLY HAVE
KW
09-28-2004 17:42:06
Last week I posted a message asking the value of a '39 Model A. Got some great responses and was able to get the tractor for a song and a dance. However, I found the S/N data plate and it has the following digits: B F.A.B. 12984. I think the owner was wrong about it being a 39 A, but I don't know anything about Farmall's, so once again, I need your help. The tractor doesn't have hydraulics, it does have a wide front end and is narrow in the rear like most pictures of A's that I have seen.
KW in Alabama
TimV
09-29-2004 05:55:18
 Re: WHAT DO I REALLY HAVE in reply to KW, 09-28-2004 17:42:06
KW: Sounds like you've got an oddball; 'Course any red tractor is better than none! Is the tractor "offset"? In other words, does the engine set off to the left of the seat, or is everything in a straight line? If it's offset, it's an "A". If not, it's probably a "B". There were no "B"'s made with a wide front end, though I've seen a couple that were retrofitted. A picture would be very helpful as well.
CNKS
09-28-2004 17:53:33
The serial number for the A is FAA, for the B, FAB. The SN makes it a 1940. I don't know what the first B is for. It is possible to put a WFE on a B, it is also possible to make a B rear end into an A. You could also have half of each tractor. Your seat along with the serial plate could have been changed. After all that, I don't know, without seeing it. See if the letters in the casting numbers are the same--in the format of month*day*year where 1939 is I, 1940, J. Don't know if there is one on every casting or not.
RobertN
09-28-2004 21:14:17
 Re: WHAT DO I REALLY HAVE in reply to CNKS, 09-28-2004 17:53:33
Look at the front of the engine towards the bottom, on the same side as the oil filter. You will see a date code for the engine. My '41 "A" has an engine date code of 12 11 J, indicating Dec 11, 1940. Makes sense for a '41 to have a late '40 engine casting. H=1938, I='39, J='40, K='41, L='42, M='43, N='44, O='45, P='46, Q='47
KW
09-28-2004 20:27:59
The S/N plate has been painted over, making it very hard to read, but the digits I've listed were very visiable. The first B is a single digit to the far left of the plate and the F.A.B. 12984 is in a continuous string more to the upper right of the plate. There are, I think, 3 additional digits in the lower left of the plate, but I couldn't make them out. Is it unusual for a "B" to have a wide front end?
farmhand
09-28-2004 17:48:23
The serial # shows to be a 1945 A if that is what it is.
CNKS
09-28-2004 17:56:19
 Re: WHAT DO I REALLY HAVE in reply to farmhand, 09-28-2004 17:48:23
Not enough digits, 1945 serials began with 113218.
