I went and did it, I have an M on my front lawn.
Richard Fazio
11-29-2003 13:15:47
So I went and did it. Got a 48 M, #163855 for $1700.00. I was a Ford man up until now, but I just wanted an M. To me the M is the most tractory looking tractor out there. It's not like I needed another tractor. I have four now. Anyway I'll have a bunch of questions for you guys. It looks like it had live hydraulics added with a pump in front of the distributor. Looks like it was using the belly pump as a reservoir. The hoses to the rear are gone. And it has a belt pulley that doesn’t turn. Could be low on fluid, there are leaks. What oil goes in the hydraulics? Is there a good site that describes the operation of this type of setup? Thanks in advance.
Nebraska Cowman
11-29-2003 15:53:00
 Re: I went and did it, I have an M on my front law in reply to Richard Fazio, 11-29-2003 13:15:47
I use IH Hy-tran in the hydralic. What do you mean the belt pully don't turn? Is it stuck? do you know how to put it in gear?
Richard Fazio
11-29-2003 16:10:46
 Re: Re: I went and did it, I have an M on my front in reply to Nebraska Cowman, 11-29-2003 15:53:00
Sorry I wasn't clear. I pull the lever and nothing happens. I can turn the pulley by hand. What is also unclear to me is how would it work with a live pump on it? In other words I can see having the belly pump hooked to the pulley. And I can see having live hydraulics for remotes. What would happen with a live pump and only the pulley? Probably hoses and/or valves were removed. The guy I got it from knew nothing about the tractor.
Nebraska Cowman
11-29-2003 16:13:46
 Re: Re: Re: I went and did it, I have an M on my f in reply to Richard Fazio, 11-29-2003 16:10:46
the pulley drives from a gear in the transmission. the hydralic setup does not affect it. When you pust in the leaver can you feel it mesh with the gear?
Richard Fazio
11-29-2003 16:41:53
 Re: Re: Re: Re: I went and did it, I have an M on in reply to Nebraska Cowman, 11-29-2003 16:13:46
Wow, thanks for getting back so fast. I thought the pulley was hydraulic because it looks like the return line goes into the top of the pulley mount. Duh! So now I realize I don't know how to engage the pulley? The lever I'm pulling I thought was for the hydraulics. It is on the lower right side below and in front of the steering wheel. It Has a three position stopper thing on it. What engages the pulley?
Nebraska Cowman
11-29-2003 16:55:38
 Re: Re: Re: Re: Re: I went and did it, I have an M in reply to Richard Fazio, 11-29-2003 16:41:53
Oh, Ok. there should be a rod down low just a simple rod with the last inch or so bent down at a 90° angle. it hooks to a short arm under the fuel tank, (top of pulley drive)push it forward to engage pulley.
Richard Fazio
11-29-2003 17:18:41
 Re: Re: Re: Re: Re: Re: I went and did it, I have in reply to Nebraska Cowman, 11-29-2003 16:55:38
Ok the rod is gone, but I see the lever. It seems to engage nicely. I'll have to get a rod I guess. Thanks so much for getting back to me. You'll see me on this board a lot in the future. I'm sure I'm going to have a ton of questions.
Nebraska Cowman
11-29-2003 17:20:53
 Re: Re: Re: Re: Re: Re: Re: I went and did it, I h in reply to Richard Fazio, 11-29-2003 17:18:41
I could make you a rod but it might be easier to measure mine and you could make your own.
Richard Fazio
11-29-2003 17:30:22
 Re: Re: Re: Re: Re: Re: Re: Re: I went and did it, in reply to Nebraska Cowman, 11-29-2003 17:20:53
That would be perfect. When you get a chance. No rush.
