Re: Re: Re: can a pto be added to an international
dick
11-03-2003 08:41:30
Adding a PTO to the 300U or 350U has been a pretty frequent topic which I don't think has a proven anwer yet. The best guess(es) so far:
If it has a TA, it "probably" is set up for PTO, and which variety can "probably" be determined by the suffix on the serial number - "S" indicates gearing for IPTO, "R" indicates gearing for a transmission-driven PTO.
A "P" suffix is supposed to indicate IPTO gearing for tractors without a TA.
About the only way you're going to know for sure is to drain the transmission, take the cover plate off, and see if the gearing is actually present. Assuming it is, I "think" you can determine which variety you have by checking with the engine off: if the gearing turns freely with the clutch depressed, but doesn't when the pedal is out, it's transmission-driven; if it never turns freely regardless of the clutch position, it's geared for IPTO.
Good luck, and please post what you find out - this is still a vague area.
tim adler
11-03-2003 16:24:20
 Re: Re: Re: Re: can a pto be added to an internati in reply to dick, 11-03-2003 08:41:30
Dick, thanks for the info. The serial # is "4581...S" and it does have TA. The cover plate that you refer to, is it the plate that covers where the pto would exit the rear of the tractor? Is there be a known source for an IPTO unit other than a parts tractor? Also, if it does have IPTO would the TA have to function properly for the IPTO to work??
dick
11-03-2003 19:12:07
 Re: Re: Re: Re: Re: can a pto be added to an inter in reply to tim adler, 11-03-2003 16:24:20
Yes, I was talking about the cover plate where the IPTO goes.
Parts tractor/salvage dealer is the only source I know about at this point.
The IPTO hooks into the driveline before the TA, so it should be independent (if all the parts are there) regardless of how well the TA is working. If you're having TA problems, first thing to do is to adjust the clutches exactly as the manual describes - you may get really lucky and find that's all that's wrong.
