Dexta clutch problems
Mike A
05-08-2002 20:59:43
I've got a 64' dexta. I had the clutch rebuilt 6 months ago, after I put the clutch back in, it seems that even with the pedel all the way out it is still not fully engaged. I can smell the clutch like it is slipping but I don't have any power loss. It has the 2 clutch plates. Is there a way to adjust the pressure with the pressure plate? The pedel adjusted to release all the way.The PTO and hydrolics are working fine just a problem with the drive clutch. I NEED SOME HELP!!
john
05-19-2002 17:52:34
 Re: Dexta clutch problems in reply to Mike A, 05-08-2002 20:59:43
third party image
Test
Paddy
05-13-2002 14:44:18
I dunno about Dextas, but on the majors there is a little rod you can adjust the length of which stems from the Clutch pedal and goes into the clutch housing. As I said, this will adjust how well your clutch engages or disengages, depending on which way you adjust it.
Hope this is of some help
