Fordson Tractors Discussion Forum
magneto
Rocky Simpson
02-20-2008 05:37:48
Is there any simple way to tell if the mag. on a 1926 Fordson is putting out any voltage?
kimmy
02-20-2008 17:30:50
 Re: magneto in reply to Rocky Simpson, 02-20-2008 05:37:48
put a voltmetre lead on the output terminal on top of the flywheel, ground the other lead to the tractor and spin the crank. The needle (analog) or the l.e.d. display (digital) should move or change to indicate a output of volts.
Rocky Simpson
02-21-2008 06:04:51
 Re: magneto in reply to kimmy, 02-20-2008 17:30:50
There is a terminal on the left side of the flywheel housing. I assume a wire goes from this terminal to the coil box. I will use this terminal to attach the meter lead to. Thanks for your response.
kimmy
02-22-2008 13:56:18
 Re: magneto in reply to Rocky Simpson, 02-21-2008 06:04:51
yes, that is the output. you can unhook that wire leading to your coil box then wire in a 6 volt lantern battery to the spot where that wire attaches to the coil box and ground the other end to the tractor and then you should hear your coils buzzing as you crank it.If your magneto is bad, you can run it this way also
Rocky Simpson
02-25-2008 05:45:58
 Re: magneto in reply to kimmy, 02-22-2008 13:56:18
Your information has been very helpful. Thank you.
