Here is what I have done many times on these steering arms. I believe you have the steering spindle with the snap ring on spindle below arm. Later style spindles had a helix style spline that when you tighten the nut it actually will tighten, kind of like a tapered spline but not quite. They are better but still can get worn loose if not kept tight. Anyway, I take the arm, slice it vertically on front, weld a heavy spacer on each side of split and put a 5/8th inch fine threaded bolt through spacers and tighten bolt clamping arm tight to splines. You need good heavy spacers. Have seen 3/4 inch bolts used also. The quality of the weld is very important.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
