Posted by BMD on March 18, 2012 at 19:19:51 from (24.125.139.102):
We have a 664 on the farm that the spindle splines are worn causing steering problem. The spindle nuts are tight as possible and still have way to much play.
The 664 has basically the same wide front as 656 utility, only real difference is the 664 is D-239 powered. It is still a great running straight tractor that tough as nails,just no where near a beauty queen.Perfect tractor for turning 6ft high briers and scrub into a beautiful field.
The 664 is used mainly used as a mowing tractor a couple times a year these days.
Been researching this forum for solutions and have 5 possible solutions. I"ll list the below. I would appreciate it greatly if anyone with experience with this problem would chime in with their advise.
Here we go.
1-Buy new spindles and steering arms. I try to always to fix things "right" but since its not my personal tractor and used couple times a year this probably would be overkill if a suitable repair is available.
2-Weld the spindles to the steering arms. Only down side is that"s a pretty drastic solution.
3-Use JB Weld or other liquid metal product on spindle splines, reassemble and let it cure a week or so before using. Not sure if its strong enough to handle the loads at the spline/steering arm interface. Also,sort of semi-permanent.
4-Use shim stock between splines and arm. Then tighten nut down good. Maybe good starting point since its not permanent before moving on to other choices. Question on type shim stock. Looks like my choices are shim stock are stainless,steel and brass. Which would work best for this?
5- Drill through arm and spindle and drive in 5/16 pin to lock them together.Possible downside is the spindle probably going to be pretty near impossible to get a hole through.
Thats all the options I can think of. If someone has any experience or advise with any of these solutions,your comments pro or con would be greatly appreciated.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
