From my experience there are straight spurr gears in the box that are directly meshed with the shaft from the opposite side. Even if it had play in and out, the gear teeth mesh would not be adjustable. A broken tooth would make a radical difference in play (pretty common) and wear would also be a factor. See if it has the same play when near the right or left full lock travel. (not at full lock) if it doesn't, there is an issue of wear or tooth damage in the center of the partial gear on tha loose shaft. If the play is along the whole length of the travel, the key might be loose at the arm taper. Be sure to look closely at the shaft to arm joint for movement. The parts diagram on caseih.com does a pretty good job of illustrating the components. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
