Posted by Dellbertt on February 17, 2011 at 04:06:34 from (209.172.21.104):
300U Manual Steering with stock short arms.
I have developed a lot of slop in the right side pitman arm (gear shaft). The right side steering wobbles when traveling and the left side does not.
Gearbox does not leak.
There is no up and down play in steering shaft and no slop or play in the left pitman arm (lever shaft)
With front wheels off the ground and holding the steering wheel stationery I can not move the left pitman (no slop) but I can move the bottom end of the right pitman more that an inch (lots of slop).
I believe the eccentric adjustment (#21 a & b IT) adjusts the right side gearbox case to mesh the lever shaft and gear shaft closer but I have to change dowels in order to make that correction last.
The other two adjusting screws (#9 IT) are to adjust any side to side slop in the lever and gear shafts. There is about a ¼ inch sideway play in the gear shaft. Is that enough to let it jump teeth.
If I have a misunderstanding of the adjustment screws please advice.
It’s just to cold in my old barn to tackle a rebuild project now, so I’m open to any suggestions that will make it last till the weather warms.
Thanks,
Dell
This post was edited by Dellbertt at 05:18:26 02/17/11.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
