tractorsam said: (quoted from post at 18:27:15 07/27/10) It's quite simple. If you remove the engine oil pan you'll see a strainer hanging down that the oil is sucked up through, I believe it's retained by a single cotter pin. Once you've removed that you'll see that the bottom plate of the oil pump (which the strainer hangs from) is only made of pot metal. Often they warp/wear and either allow enough oil to bypass and cause a pressure issue or due the warpage the gasket will blow out. Remove the four bolts that retain the bottom cover, be careful as one of the oil pump gears will also likely fall out. Once you have the cover plate off you can either get it machined flat, use a piece of course emery cloth on a flat surface (such as a robust sheet of glass), or if you're very good file it flat. Hope that helped, Sam
If you'll remove the complete oil pump assembly and support it upside down in a bench vise, you can then remove the bottom cover without the gears falling out. (just a hint)
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
