It's quite simple. If you remove the engine oil pan you'll see a strainer hanging down that the oil is sucked up through, I believe it's retained by a single cotter pin. Once you've removed that you'll see that the bottom plate of the oil pump (which the strainer hangs from) is only made of pot metal. Often they warp/wear and either allow enough oil to bypass and cause a pressure issue or due the warpage the gasket will blow out. Remove the four bolts that retain the bottom cover, be careful as one of the oil pump gears will also likely fall out. Once you have the cover plate off you can either get it machined flat, use a piece of course emery cloth on a flat surface (such as a robust sheet of glass), or if you're very good file it flat. Hope that helped, Sam
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
