mkirsch said: (quoted from post at 14:09:16 07/08/10) Are you saying that you put the resistor BETWEEN the coil and the distributor?
You need to put the resistor between the ignition switch and the coil.
That's why the coil is getting hot.
If you make a drawing of the electrical circuit you can see that it makes no difference in the primary circuit which side of the coil has the resister. The resistance of the coil and the resistance of the resistor are in series so the current draw of the coil will be the same either way. By putting the resistor on the battery side of the coil it is possible to bypass it for more voltage for starting.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
