*SUPER -M- RUNS AGAIN*
Posted by gatorhide on July 07, 2010 at 21:19:46 from (24.155.13.131):
I want to tell everyone that helped me with the ongoing advise *THANKS TO ALL OF YOU* the M runs again.
The reason she would not fire was because I didn't pull the plugs and put the #1 piston @T.D.C. I also didn't pull the distributor and back to a position so the rotor would point to the #1 piston.
I did these things yesterday correctly and she fired right up.
I'd like to know what the ideal/normal water temperature should read on this tractor? At normal operating temperature mine reads right at or just slightly below 160 degrees.
Thanks again for your help. I appreciate it very much. gatorhide
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
