Posted by ScottyHOMEy on August 20, 2009 at 15:07:41 from (71.241.214.214):
In Reply to: HOT COIL posted by Bonnie Tallman on August 20, 2009 at 14:26:47:
You need to check out Bob's idea about the resistor and whether or not your coil needs one.
More to the point, if your condenser is hooked up as you say, it's wrong. If you are set up for negative ground (battery - to chassis) the + terminal on your coil should be connected only to the hot lead from the battery/switch. The wire connected to the - terminal on the coil should run down to the distributor body and connect to an insulated stud on the outside of the distributor body that conducts the juice to the points and condenser, which are connected together inside the body to the inside of the stud.
You've either got the condenser in the wrong place, or what you're looking at is not a condenser.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
