Posted by Bonnie Tallman on August 20, 2009 at 14:26:47 from (98.18.242.15):
I am trying to get an old farmall M running. There are problems with the ignition and/or the starter switches - so for now I am by-passing those switches and hot wiring from the pos battery cable to the starter to just get the tractor to start.
However - I have had two coils get so hot they cracked and oil leaked out. What would cause this to happen? I am using a 12 V battery and a 12 volt coil. I have the ignition wire running from the pos battery terminal to the pos coil terminal - the condenser is connected to this same pos coil terminal. A short 14 gauge copper wire is connected from the negative coil terminal to the distributor. I have new plugs and plug wires. The tractor will start and run for maybe 5 -10 seconds and then stops - acts like it is not getting enough gas - however after about three attempts at starting the coil then gets extremely hot. Any ideas? Thanks
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
