Re: Farmall M - Converting to Alternator and/or El
Posted by John T on September 27, 2006 at 05:41:50 from (66.244.90.5):
In Reply to: Farmall M - Converting to Alternator and/or Electr posted by David Hazelwood - TN on September 26, 2006 at 20:55:08:
David, If youre gonna convert to 12 volts and want to use an alternator, I WOULD CHANGE OVER TO NEGATIVE GROUND cuz all but a few expensive specialty alternators require Negative ground... NOOOOO the 6 volt starter will work, Ive never had one go bad buttttttttt avoid real long cranking periods and it can be a tad tougher on starter drives..... Of course, change any light bulbs over to 12 volts. As far as IGNITION CHANGES for converting from 6 to 12 volts, you must EITHER add a series voltage dropping (12 to 6) external Ballast Resistor in the primary ignition circuit after the ignition switch and before the coils input orrrrrrrrrrrr else get a replacement full true 12 volt rated coil, otherwise the 6 volt coil would get too hot n go bad plus the points will burn up prematurely. ALSO if you change the ground to negative, the coil leads need reversed so the + gets voltage from the switch/ballast and the - wires to the distributor ALSO if you change ground, the ammeter leads need swapped or else it will read bass ackwards I prefer the GM 10 SI Alternators (3 wire but configured for one wire operation) as they are readily available,,,,,,,low priced,,,,,and dont require any high PRM to excite nor is trickle discharge when setting long periods much of a problem versus some One Wire alternators. If you want my description or Bobs neat picture or Bob M's diageam of how to wire them, post back for instructions. ELECTRONIC IGNITION they are made for either + or - ground but I recomend you go - ground as an alternaotr is cheaper that way. If you use an electronic switch I HIGHLY RECOMMEND to get the most bang for the buck and to utilize all the advantages the elec switch has to offer, to couple/match it up with a high energy coil instead of just using the stock coil... Have the elec switch vendor match the coil for the switch and I would run a bit wider plug gap and use good quality plug wires n distributor cap n rotor. Best wishes n God Bless John T
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
