Re: Re: Re: Re: Electrical problems!
Posted by Bob M on July 28, 2003 at 07:28:52 from (165.170.128.66):
In Reply to: Re: Re: Re: Electrical problems! posted by 49 Cubber! on July 27, 2003 at 19:12:18:
Hey 49 - Ammeter should show a small charge (a couple amps) on low charge with the motor at governed speed. The discharge indication you are getting is puzzling. You sure the ammeter is working correctly? Check by sticking a voltmeter across the battery terminals with the motor running at speed. A reading of 13.5 volts or higher says the battery is being charged. It's normal for the field resistor to get warm in operation. However it will run pretty hot if you are using the old (6 volt) resistor on 12 volts. (On 12 volts it must dissipate 4x the heat it was originally designed for...) Changing over to a regulator is straightforward. It gets wired same as the cutout except for the wire from the "F" terminal on the generator. That wire gets relocated from the light switch to the "F" (or "FLD") terminal on the regulator. (The BAT and GEN wires get connected to the regulator same as for the cutout.) Make sure the regulator is solidly grounded! Running an auxiliary ground wire from the regulator base to a solid ground on the engine or frame is good practice. Also the regulator will last longer if it's physically mounted where it is away from vibration/heat - NOT on the generator if at all possible!!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
