Two different answers to your question. You are asking what to set time for the most power and getting answers for IH setting. IH didn't set those engines for total power. They set them to last all day with the throttle pulled back and plowing or other heavy work. Depending on use, fuel grade, cooling, and fuel mixture setting you may get by with a higher time. Some tractors have 4 timing notches. If you have 4 and count TDC as one. The 3rd notch is 22 degrees. If 3 notches the 3rd is 30 like you posted.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
