I also believe you need to check the marks on the pulley. One way to really be accurate is to make a piston stop out of a spark plug. Gut a used plug for the engine, leaving only the shell. Find a piece of steel rod that fits in the shell and braze it in place sticking out an inch or so. Round the end of the rod into a dome (not accurate or polished, just not sharp edged). Screw it into #1 plug hole (all other plugs out)(with the piston going up, stroke does not matter) Using a hand crank, !!!not the starter!!! roll the engine till the piston touches the rod and stop. Mark the pulley at the pointer. Turn the engine backward (using the fan belt) till the piston touches the rod softly from the other direction. Mark the pulley there. Now use a tape measure to divide the two marks giving a very real TDC. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
