Posted by IH fan on February 18, 2015 at 13:25:06 from (68.103.185.25):
In Reply to: 1256 Repower?? posted by wilamayb on February 17, 2015 at 13:43:01:
Unless the crank is really beat up bad, it should be capable of a re-build. Magna-flux to be sure it isn't cracked before re-building it unless it's obviously broken. Sounds to me like it's a common engine, so even though the other internal parts are no doubt different, the crankshaft might be the same on many versions of the 407.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
