Posted by DeltaRed on February 17, 2015 at 14:40:06 from (65.100.146.228):
In Reply to: 1256 Repower?? posted by wilamayb on February 17, 2015 at 13:43:01:
The 856 did use a 407.But that's about where it stops.More cooling cap,oil jets to cool HOT pistons other stuff.....Fix what what you have.In the long run,still the best option.By the time you BUY a good used 414,436,466 plus all the other stuff,you will have WAY MORE money in the beast('franken tractor').Again,fix what you have.Then you will still have a good "sellable" tractor when you are finished.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
