All 3 ports have pressure out and fluid return through the same ports. Only can use with single acting cylinders unless another valve is added to the system. If hooking to a single acting cylinder on each side of tractor, use the right and front left port. Left rear port has a separate check to open when lowering. Pull rod back to get pressure and push forward to lower. Yes that's the fill cap. If its still there it will have a fluid level dipstick under it.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
