Not a rare option, as explained below, these came with a #24 mounted corn picker. The part you see outside the cap are really extensions of the nuts that hold the wheel bearings in place with a different type of hub cap. You probably do not have a bearing out, its most likely the seal on the hub cap that has gone bad. Good luck finding a seal, if I remember fight, they were raw hide. If you want to replace them, you will have to find a couple of nuts and new hub caps. I think I still have the original nuts and caps that were on my Dad's H before it became his picker tractor someplace. I still have the tractor and it still has the #24 picker hub caps on it. (My $0.02 worth. jal-SD)
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
