A picture would help alot. Depending on when it was made, a 2pt. plow could be in a couple of different parts books covering plows, or the parts books covering equipment meant for the SC-200-230, or 300-450 tractors. Looking through the indexes (or is it indicies) in all of these books would find your part number.
If you only need wear parts, you do not need to know what model of plow you have. You need to know what types of bottoms you have. Again, a picture would help, or part numbers off of the backside of the wear parts would be needed to determine this.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
