Procedure for removal is to take off the timing cover on side of pump. Little plate with two screws. Turn engine until the timing mark on governor aligns with stationary mark you see inside. It will only align with number one piston on compression stroke and should be at 3 degree before top dead center on the front pulley. Might be a degree or two off and you may very well have to turn engine two full revolutions because pulley marks will align on number six also but pump will not on that engine. As long as you are taking it off you may as well pull top cover to make sure metering valve is not stuck or something came unhooked. Also, a rap on the side of the pump with a plastic hammer might just get it going again, never know.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
