I had a almost same problem.My 560D would not start and I had just ran it a few days before. I checked and good flow to pump, glow plugs working fine and spinning over good but no smoke.I talked to an old tractor mechanic and he told me sometimes he has seen the pump shut off plunger get stuck.I tapped on pump while had dads spin tractor over and started up, this was about a year ago and still starting up ok.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
