Posted by Janicholson on September 02, 2013 at 15:24:24 from (74.60.94.18):
In Reply to: Re: Giving up on MD posted by kluegcollector on September 02, 2013 at 12:45:57:
The fact that it runs on the D side is great. The pump is not tough to look at and fix. The problem may be that the rack is stuck. only allowing a small amount of injection. Take the cover off and look at the system to see if there is movement when operating the fuel lever (throttle) a little solvent and effort might get it operational. Some older local person and a case of malted beverage and it runs. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
