Posted by Larry B. 1486 on September 02, 2013 at 14:50:49 from (98.19.160.237):
In Reply to: Giving up on MD posted by kluegcollector on September 02, 2013 at 11:49:51:
Have you checked the filters? Are you getting enough fuel to the pump? It don't sound like all pump problems. I owned a SMD years ago and the butterfly in the intake manifold did not operate correct and it would not pull itself, loss of power. Linkage to your compression release valves might have the valves open. Make sure everything is shut off on the gas side when you switch it over to the diesel side.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
