Posted by rdpavlis on August 03, 2013 at 13:15:29 from (70.197.196.227):
In Reply to: Re: 46 H Drum Brakes posted by Janicholson on August 03, 2013 at 07:25:36:
Some years back I rebuilt a Farmall A and the brake linings were completely soaked in transmission grease. At that time I had a book that said I should burn them with a torch. I did that and they burned completely clean. The problem is that the brakes are very sensitive such that if you step on the brakes with any force at all the wheels lock up. It is kind of like having power brakes, but is actually too sensitive. Something must have burned out of the linings that they operate that way as I have a Farmall B with new brake linings and they work normal. Thought I would ask if anyone has any explanation for this. Roger
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
