Posted by notjustair on August 03, 2013 at 12:00:59 from (174.237.165.251):
In Reply to: 46 H Drum Brakes posted by LJW on August 02, 2013 at 18:38:24:
Also make sure there isn't any play in anything (like the hole in the trans case wollered out). If the brake shoes can move side to side in response to the pressure they will be working cockeyed. That can bind them and cause them to chatter.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
