Posted by DaveLamp on February 25, 2013 at 06:56:01 from (69.54.29.239):
In Reply to: Super C governor posted by Rick Remmert on February 24, 2013 at 17:19:44:
If the "cage" is good on your thrust bearing you can get new bearing balls at your local bearing shop (Eastern Bearing Co. here in Vt.). I did and it only cost me around $5.00
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
