Posted by Phil Tibbetts on February 22, 2013 at 13:18:32 from (208.93.14.38):
Anyone know why the clutch pedal on a B414 gas will not go all the way down. When you push it it goes half way and stops. It acts like something is stuck. I bought this not running last fall and it has been too cold to work on it but I know this problem exists. The motor is not stuck and I plan to get it running when it warms up. I rebuilt the carb this winter. It also has an electric fuel pump but I don't know why as the engine driven fuel pump seems to be ok. I also have a 364 diesel and that also has an electric fuel pump same kind (Facet). Is this some sort of factory retro fit?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
