Posted by Lmack on January 02, 2013 at 18:25:48 from (24.131.58.167):
In Reply to: 230 water pump posted by tntleake on January 02, 2013 at 17:47:30:
The nut does not turn. You have to turn the 5/8" bolt on the front. The bolt on the back fits in a grove so that it will not turn at first. You can use one wrench to loosen the 5/8" until it has so much slop that the inside nut starts turning. You will need to use two wrenches at that point. It goes back the same way. At some point the rear nut will grip the grove and you will only need a wrench on the front nut. One of your other hands (I am serious) will be on the crow bar you are using to tension the belt. Use the rear nut as a lift point for the crow bar across the governor housing. Make sure the threads in the nut and on the shaft are clean. I would suggest running a tap into the nut and a threading die over the bolt threads. They need to turn easily and have a little oil when you reinstall. You have to get the 5/8" very tight or the fan pulley will simply drop down when it gets hot.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
