Posted by Don R of MN on May 12, 2012 at 08:31:30 from (173.141.131.197):
In Reply to: Stuck 450 Diesel posted by Hfarmall on May 12, 2012 at 07:14:22:
I believe it would be best to pull the motor, get on the floor or engine stand. At that point it will be easier to maybe get at rod bolts so you can then pull the crank. Then you can get the block in a press that will make piston removal a lot easier. When you get the pistons out just press the pins out.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
