Well when it first happened I was plowing (under heavy load) and I noticed the hood wet around the cap and water apparently coming from under the cap. Whenever I removed the cap (later after it cooled) I put water in until it was at the bottom of the neck. Started tractor. Ever so slowly, the water level got higher and higher until it was trickling over the lip. Never had it gushing out or bubbles, just slowly rising. Now it had to have had a bit more than a trickle of force when it came out when in use, but then it would have been hotter and under pressure too.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
