No test that I can think of that dose not involve trearing into the motor. You said it has just happened, so if indeed there was a crack, oil and coolant would both mix with time and use. Is your coolant good for -30F? If the anti freeze in the rad was slush, it could buble out the over flow , But this would only happen if tractor was use for say short periods of time, like ten minutes to move a round bale or such.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
