Posted by Aces on February 02, 2012 at 08:26:00 from (66.172.223.13):
In Reply to: Farmall Bolts posted by schultz on February 02, 2012 at 05:09:17:
Schultz! If you go back to the H,m through the 450's you will see the IH bolts with the dot in the center on side rails and clutch housing to rear end. Had all kinds of trouble with them coming loose. Then the 460 560's had grade 8 with stare washers, that was better. 706 806 656 had grade 8 and no washers. No problem coming loose. So I used grade 8 and no lock washer on all tractors after the 06,56 came out. Just use a long wrench a tighten them up goood. I will not use a lock washer on anything,, waste of time and money.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
