when i get one like that and as I turn it out, if it is squeaking, I stop and spray penetrant oil all around the base of the plug thread.. then actually screw it back in, and repeat.. each time it usually gets looser as the penetrant wicks in.
have saved time NOT breaking plugs that way
have seen plenty of peple pull threads out of heads or break plug bases off in heads by cranking a squeaker out.. sometimes it's carbon.. sometimes rust. neither is good on a hard pull though.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
