Posted by CNKS on November 13, 2011 at 17:35:58 from (216.144.104.128):
In Reply to: Convert A to Super A posted by equeen on November 13, 2011 at 11:01:32:
You can take the torque tube from the SA, plus the hyd resevoir, pipes and the touch control levers and rods, etc, along with the pump if it is still functional. But you will need another SA or C engine to add the hyd pump. The SC engine will also work, but you need a SA or C radiator for the sheetmetal to fit if you don't have one.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
