One little detail here. Firing cycles are not in hertz. Yes they fire so many times per second, but blow down time for a cylinder has nothing to do with cycles per second. Blow down is just an ordinary exponential time constant. It takes so long to blow down and that is that.
What it means is that a cylinder pops a pulse into the pipe. Separation time between pulses is the major factor in all exhausts. It is why you cannot turn a 3 cylinder engine at a higher speed and make it sound like a 4 cylinder, or a six, or an 8. It is why they all sound different. Putting more cylinders on the same pipe eventually causes the pulses to run together, to the point that an 8 or 12 has almost no distinguishable pulses at all.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
