I am in the same boat. Make sure you get the correct brushes. I made the mistake of getting a starter "rebuild kit" from an ebay seller, and the brushes were not correct.
My recommendation is that you go to a local starter/alternator repair shop and get the correct brushes/springs/bushings. Also while you are there, have the shop turn down the commutator on your armature on their lathe.
The local shop is going to be your best source of information. They will be able to tell you if your coils/shoes are grounded (bad), condition of the terminal stud and condition of your armature.
I went through all of the above learning the hard way...
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
