That H will definately need at one set oaf weights and probaly 2 sets to do what you are wanting to do. Also if you plan on mounting anything on the 3 pt. hitch including a snoublower you will definatly need front end weights. I have an 8 ft. snow blower on my 560D with at least 500 lbs. of front weights plus a loader and I still feel the weight shift when I pick up the blower. Also to run that blower you will need live power takeoff and live hyd. if you don"t already have that. By the way that snow blower will make that Diesel smoke black like it"s pulling a 4x16 plow. The last time I checked the hp on that tractor it was set at about 67hp. to power a John Deere # 6 corn sheller. Armand
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
