Posted by CNKS on February 19, 2011 at 07:01:36 from (216.144.104.128):
In Reply to: Re: Super A rebuild posted by ScottyHOMEy on February 18, 2011 at 21:39:50:
Clutch had a roller bearing, was quiet before I tore it down -- probably another one of my goof ups. I notice that the difference between the levers and the bearing are supposed to be 1/2 inch (graphite bearing if that makes a difference) that seems extremely wide. Mine are maybe 1/8, if I adjust the pedal play to get that 1/2 inch, I will have about 2 inches free play in the clutch pedal and I am sure it won't go into gear. With the current setting it shifts fine and the bearing does not touch the fingers at full rpm.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
