I apologize if I am not understanding your question. I use parts catalogs to get specs on hardware. For Cub tractors the catalog can be found on the Cub site. For SA/SAV I have a parts catalog here and would be happy to look up something if you drop a post on it. Others might too.
Unfortunately, for springs there is not a lot to go on. The diagram gives you a good picture if it is completely missing. The text more often than not just says "spring". My best efforts in this regard would be called trial and error. Buy a handful, try them out, return them what don't work.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
