I already have an H with weights, loaded 14.9/38 tires with chains and a good running engine, so I'm figuring I may be ahead to move the loader onto that tractor and then figure out what to do with this one. I'll bear in mind about the hood, I need to find a local friend with good sheet metal skills like yours. I haven't found the block heater yet, which side is it on? Thank you very much. Zach
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
