Posted by Leon Torkelson on November 25, 2010 at 20:17:08 from (74.44.13.237):
In Reply to: Farmall H spark plugs posted by James MN on November 25, 2010 at 19:41:12:
Those look like the adapters that are sold to Ford Model T owners so they can use standard size spark plugs. Plugs for Model T s run form $5.00 to $25.00 each depending on how authentic you want your car. So standard size plugs in the same heat range are used to save money. That may be what happened to your tractor. You can use one of those adapters on a compression guage since they don t come with fittings for the large threads.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
